M Rumley OilPull, Oil ???,fuel pump ??
Mike3
11-21-2002 07:36:20
My 20-35 M Rumley needs oil in the cooling system, What oil should i get for the radiator? The fuel pump doesn't pump, any one have any suggestions? The check valves seem to be in good shape. Thanks
Nobul
11-23-2002 17:44:32
 Re: M Rumley OilPull, Oil ???,fuel pump ?? in reply to Mike3, 11-21-2002 07:36:20
Your cooling system will be happy with a non-detergent oil, something 20-30 weight is usual. Some use a hyraulic oil. Must be non-foaming type. The seals on the pump must be tight to prevent air induction and foaming. The fuel pumps rely on a liquid seal to work properly. You may have to fill the chambers manually to prime them. I have seen many operators use a stick or rod of some type to manually operate the pumps through the top of the carburetor before starting to fill the carburetor. Chances are you will need to rebuild the pumps to get the seal needed to make the work. Good Luck, Rob.
