Super G 1000
Farmered
12-05-2002 05:44:25
Does any one know where there is, or anything about a John Blue Super G 1000 tractor? John Blue (the sprayer co.) Built the Super G 1000 to fill the gap left when AC quit building the G in the middle fiftys. It was a Ford powered rear engine cultivating tractor. I talked to long time employee at John Blue and he seemed to remember that they built about a hundred of them. I remember the sales literature but I have never seen one.
Robert in W. Mi.
12-05-2002 09:27:34
 Re: Super G 1000 in reply to Farmered, 12-05-2002 05:44:25
third party image
I've seen several of these in my area. I've never run one, but i have looked them over. Some models (there's more than one) have OHV engines, so they don't all have the "cub engine" mentioned below. Hope this helps, Robert
Larry from Maryland
12-05-2002 08:53:15
They used a IH cub engine.A friend has one and we did too for a little while.Parts for the rear are not available,we know because they go bad.Biggest problem was the spline shaft between the trans. and the rear.This shaft was made too short and would slide to one end and leave just a small area where the splines would cantact.The shaft would soon fail.We welded 2 shafts togather and stuck them in,that has held.One reduction gear by the rear wheel went bad,numerus fan belts,and the steering gear is bad too.The fan belts are hard to replace,but the big problem is the engine is behind you so the driver dos not see the engine overheating.
Nita Moorman
05-31-2005 06:17:01
 Re: Re: Super G 1000 in reply to Larry from Maryland, 12-05-2002 08:53:15
My boyfriend has one and he was one of the Engineer's who did some of the design work on this tractor at the John Blue Co. in Huntsville years ago. Do you still have yours and want information on it. I just saw this site and wanted to konw, I will tell him tonight about you notice. He knows about this tractor. Nita
Farmered
12-06-2002 00:32:29
Thanks for the reply Larry. Should be glad I didn't get one. Don't know where I got the idea that it had Ford power,guess it must have been the blue color.
Ed
steve texas
03-14-2003 20:02:55
 Re: Re: Re: Super G 1000 in reply to Farmered, 12-06-2002 00:32:29
I had a g-1000 it was a graet tractor as a matter of fact Im going tomorrow to pick up another one they very simple to work on and you can rig just about anything on them yourself . but they are just cultivators not tractors so treat them right and they do fine
Loyd Earles
10-30-2004 14:06:21
 Re: Re: Re: Re: Super G 1000 in reply to steve texas, 03-14-2003 20:02:55
I have a G1000 John Blue In great shape. In Va . Would like to hear from other owners
