Long hydraulics
NC Shepherd
01-15-2003 19:43:08
I have a Long 445 (diesel) which I purchased used with a front end loader. I've had it over 3 years and it has performed great. In the past several months, the loader shakes when lifting and lowering (even without a load), but the implement lift is working great. I am clueless when it comes to hydraulics so any info and suggestions would be greatly appreciated. Thanks in advance.
Jason
01-19-2003 17:06:15
 Re: Long hydraulics in reply to NC Shepherd, 01-15-2003 19:43:08
does your loader run off the pto pump in the back of the tractor just above the pto shaft if so the loader has its own oil tank
geok
01-16-2003 18:26:04
When was the last time you cleaned or replaced hydraulic filter? It is located on right side of engine inside a tube on the intake line. Two bolts are used to hold cover on.
