1974 Yale 4000# Forklift
Inez
01-31-2003 19:15:51
Steering works hard/slow. Can anyone offer help. Fluid levels OK, raises, tilts, lowers OK. Has Continental 4 cyl engine, LP gas, automatic 2-speed transmission - forward, reverse. What would make it steer hard?
mechanic32
03-02-2005 16:48:53
 Re: 1974 Yale 4000# Forklift in reply to Inez, 01-31-2003 19:15:51
Underneath the steering wheel is a steering orbital motor. Fancy name for a hydraulic gyrometer. These will wear out and cause hard steering. If everything else is ok this is where i would go. Been in the forklift business for 15 years.
geok
01-31-2003 19:49:49
First thing you would have to check is fluid pressure. If your machine is equipped with power assist and pressure is normal, you may have to replace control valve. I am relaying what I experienced with a 5500 lbs. Clark.
Jordan
02-15-2004 02:18:08
 Re: Re: 1974 Yale 4000# Forklift in reply to geok, 01-31-2003 19:49:49
could i please see a pitcher of the 1974 yale forklift. thanks
Inez
01-31-2003 20:13:18
What should normal pressure range be, do you know?
Appreciate your help.
geok
02-03-2003 16:53:12
 Re: Re: Re: 1974 Yale 4000# Forklift in reply to Inez, 01-31-2003 20:13:18
On a Clark IT-60 the p/s pump is set at 2 gpm, 2000psi.
