Avery fuel lines
Clarence Davis
02-16-2003 20:56:42
Can anyone tell me where to route the fuel lines on a 12-25 Avery tractor. Over/under engine, pulley or clutch side? Took it apart six years ago and forgot where they go. Thanks
Craig
02-19-2003 15:53:19
 Re: Avery fuel lines in reply to Clarence Davis, 02-16-2003 20:56:42
third party image
Which style fuel tank/tanks do you have? My 1914 12-25 has a single tank but a friend in MN has one with the stacked tanks. Either way, the fuel lines come off the tank--go forward--then down and over to the right side below the cylinder and then forward to the carb. Things get a little tricky at the carb if you have the double bowl Kingston. Hope this helps!! It should if you still have the original lines. Craig
