Red Seal tractor
Phillip Wright
02-21-2003 07:29:24
6 cylinder continental engine. It kind of resembles a Massey Harris gas tank. Hood is missing, the only name is Red Seal on both sides of the grill, I'm thinking it is some kind of industrial tractor. Any help identifying this tractor would be appreciated.
Thanks,
Flip
Richard
02-22-2003 05:24:41
 Re: Red Seal tractor in reply to Phillip Wright, 02-21-2003 07:29:24
As noted by the other two responses, the Red Seal was a Continental power unit. I know Worthington tractors used the Red Seal with the Red Seal logo pressed into the grill. Look around on the tractor and don't be surprised if you find a Worthington ID tag on it. (If you are not familiar with Worthington, they made tractors that looked like cut down trucks--not farm tractor like at all-- to pull gang mowers on golf courses, etc.)
Walter Fulford
08-17-2003 11:05:56
 Re: Re: Red Seal tractor in reply to Richard, 02-22-2003 05:24:41
I have a Worthington G6 with a Cont. Red Seal in it and would like to find out what year model it is. If anyone has info. concerning this please e-mail. jwaltfulford@aol.com
ED in Vancouver,Wa
09-27-2003 23:38:33
 Re: Re: Re: Red Seal tractor in reply to Walter Fulford, 08-17-2003 11:05:56
I also have a 4cyl. Red seal motor.It was used on a drill machine and has a dual clutch w/forward and reverse.have all running parts and sheetmetal...it looks like the front of a crawler and has RED SEAL stamped onto both sides of radiator housing...want it?
Alberta Mike
02-21-2003 09:56:37
Red Seal was a trade name that Continental once put on many of their engines, specifically the flathead 4 and 6-cylinder versions I believe. Now, if the engine was originally a power supply engine and was mounted on a skid with a radiator and some enclosing tinwork, I imagine the radiator shroud might have the Red Seal decal on it. Any chance it was transplanted into a tractor? Here's where a photo could speak a thousand words right?
Larry from MD.
02-21-2003 09:32:41
Red seal is a trade name of continental engine company.You offten see their power units mounted up on some other make tractor.
