Water pump for HOUGH Payloader Model HF
Tom
03-04-2003 04:58:06
Part is for a HOUGH Payloader Model HF, which has a 6cyl Hercules gas engine. Only words/numbers on the engine are HI-CHROME and K112 (Casting #??). The water pump shaft also drives the distributer. Any idea where we could find one? The old Payloader is used in a marina on a daily basis.
Thanks,
Tom Assenmacher
Kinsale, VA 22488
Email: tjkassen@sylvaninfo.net
peter antognoni
11-02-2003 13:43:30
 Re: Water pump for HOUGH Payloader Model HF in reply to Tom, 03-04-2003 04:58:06
try Link
waverly bugg
03-28-2003 21:16:45
i'll send an email on who can help you.
Bus Driver
03-06-2003 16:50:50
Not at all sure that my notions are correct in this case, but I think that Hercules has been out of business for several years. Used to see ads from companies that offered parts for Hercules engines. If I was looking for such a part, I would use Google search engine and start with "Hercules Engines". Probably lots of sites will be referenced. If no luck, try "Hercules engine water pump". One thing that may really help is the likelihood that this model engine was used in several different types of equipment.
Tom
03-06-2003 18:15:43
 Re: Re: Water pump for HOUGH Payloader Model HF in reply to Bus Driver, 03-06-2003 16:50:50
Thanks for your recommendations - been there and done that - got a couple of recommendations from the crawler section of the forum.
Bus Driver
03-06-2003 16:53:18
Also suggest that you post your question on the "crawler" section here at YTMAG.
