Wain roy transmission problem--reversomatic
david allard
05-17-2003 17:54:05
when i drive my wain roy "rustler" backhose on level ground it goes along and shifts withous any black smoke. when i attempt to go up a hill or start up a hill with a head start it bellow a large qty. of black smoke and stall out. any suggestions. i have rebuilt the fuel injections pump,fuel injectors and rebuilt the engine.i am wondering if the reversomatic transmission that operates off of the hydraulic system has anything to do with it?? slipping clutches maybe??? bad hydraulic pump??? can anyone help me????? ???? finders fee to the correct solution!!!!!
thank you
you may call me at 800-646-1021
or email me at david61@cox.net..... ..
alfredo maliachi
12-14-2006 14:56:31
 Re: wain roy transmission problem--reversomatic in reply to david allard, 05-17-2003 17:54:05
Gentleman, Please, can you help me I need parts this TRansmission REVER-ON-MATIC
MODEL 500S55A0000 SPC 5394A. Do yaou have this parts transmission, Thank You
Gus Demetriades
05-11-2005 18:15:38
Hi, I am afraid I cannot be of much help. I did put in a new cessna pump and it improved the drivability of mine.You may have a gearing issue. It seems like maybe you are in too high a gear for climbing hills. Do you stall out when you are digging with the front blade and driving at the same time? I am also looking for a copy of the manual if you have one and could copy it for me I would be much obliged.
