Honda 4518 lawn tractor
Dan
05-18-2003 08:12:15
I know this questions comes for the moron section, but this year, I've had nothing but over heating problems with my 4518. Took it in for service, the mechanic said dirty air filter was biggest problem. $300+ dollars later, I mow half of my lawn & park the tractor. Several hours later, I notice a large puddle underneath the tractor. I check the antifreeze overflow and it's bone dry.
Two part question. what's going on? and do I put car antifreeze into this? I can't find my manual and Honda.com doesn't have a reference manual on line.
Thanks for any help.
Dan
PK
08-29-2003 07:18:18
 Re: Honda 4518 lawn tractor in reply to Dan, 05-18-2003 08:12:15
Clean the radiator screen and the radiator. We have a very large area to mow and have to stop regularly to clean the screen in front of the radiator. We have made it a habit to clean the radiator very thoroughly with compressed air after each use. You should also make sure the thermostat is working properly, and that none of the coolant hoses are crimped, or crimp when hot. We've had good service, for the most part, out of this lawn tractor. We have to replace the blades annually, and typically at least one of the deck belt pullies will go out each season.
I have found a guy in WI that's got several of the 42" decks for sale, new in the box.
Dan Alexander
08-22-2004 08:35:15
 Re: Re: Honda 4518 lawn tractor in reply to PK, 08-29-2003 07:18:18
Where is the thermostat located? I'm thinking of removing it.
vaughan
07-14-2004 13:05:01
Could I get the name of the supplier for the honda mowing decks. I'm also interested in a mower bag attachment.
Thanks
Brian
06-25-2003 05:00:50
Have someone check your thermostat, it may be stuck or broken. If that fails, do a compression check to make sure head gasket is not leaking into coolant area. Add 50/50 mix to overflow bottle as this should be maintained at the indicated levels show on the side of the white plastic container.
Bob
06-11-2004 12:38:07
 Re: Re: Honda 4518 lawn tractor in reply to Brian, 06-25-2003 05:00:50
I am trying to find a grass catcher for my H4518. Honda doesn't manufacture or sell them anymore. Can anyone recommend an after market fit or a place to buy a used one?
Anthony Taylor
07-09-2004 11:11:49
 Re: Re: Re: Honda 4518 lawn tractor in reply to Bob, 06-11-2004 12:38:07
Does anyone else out there have a complete bagging kit for the 4518 or 4514?
service
06-28-2007 13:33:04
 Re: Re: Re: Re: Honda 4518 lawn tractor in reply to Anthony Taylor, 07-09-2004 11:11:49
help, I"m trying to wire a universal ignition switch into my 4518 honda. I have no schematic to help me with what the numbers stand for. I have a bk/y, an w, an bk/r, bk/w, and a black. Can any one tell me what goes where? new switch has an r, a, I, s, b, thanks jim
Ron O'Bryant
06-25-2004 08:23:30
I have a grass catcher for your H4518
Make me an offer.
Greg Furch
05-16-2006 15:55:17
 Re: Re: Re: Re: Honda 4518 lawn tractor in reply to Ron O'Bryant, 06-25-2004 08:23:30
This is a message for Ron O'Bryant,
Ron did you sell the grass bagger / catcher for the 4518?
Was this amde by Honda for that model, or is it an aftermarket unit - if so what kind.
Thank You
Greg Furch
Bob Russel
06-28-2004 10:48:21
Is it new, used, and if used what condition?
