Economy tractor voltage regulator woes
Marc
05-21-2003 08:00:55
Hi. New to this board. I have a very old Economy Tractor. The voltage regulator rectifier on the back of the dash panel shorted and melted. It is a Repco FG4175 with 3 posts leading to it. Any help finding a replacement or any suggestions greatly appreciated. Thanks in advance
Sky Bartlett
05-25-2003 14:30:11
 Re: Economy tractor voltage regulator woes in reply to Marc, 05-21-2003 08:00:55
Try a Kohler parts dealer, they sould be able to get one.
gilbert gauvin
08-15-2003 19:26:30
 Re: Re: Economy tractor voltage regulator woes in reply to Sky Bartlett, 05-25-2003 14:30:11
have good news you can use a harley davidson voltage regulator to replace that repco fg-4175 I just did it on my roper tractor and it works much better it holds 14.6 volts and puts out more amps under load all you need to do is cut the plug off install some stakon wire terminals wire it to the stator and ignition terminal bat+ and your golden the part number is 74512-79A good luck
