Huber tractor
Bill
06-16-2003 05:01:14
I was receently offered a Huber Model B. I haven't seen it yet & know nothing about it other then it is a narrow front end and supposedly has a Buddah engine. Does anybody have any info on this tractor?
Craig
06-19-2003 21:04:31
 Re: Huber tractor in reply to Bill, 06-16-2003 05:01:14
And it would be a MAJOR plus if the original headlights are still there tucked behind the grill!!
Brent
06-16-2003 18:02:38
Bill I can help you with some info. Huber was a very old company that originally built steam engines. The model B was the last new farm tractor Huber would build. It was built between 1937 and 1943 ('38 seems like the biggest production year). Depending on the year of your Huber it would be red,green,or grey in color. The B was the only Huber farm tractor to use the flathead Buda four cylinder. PTO was an option on the B. Parts can be a little hard to find but they are still out there. Hubers were built in Marion,Ohio and the Huber Museum is still there.
I own a 1938 Huber B,so I can try to help you. By the way the serial number should be on a metal plate on the right side frame rail.
Bill
06-18-2003 08:54:33
 Re: Re: Huber tractor in reply to Brent, 06-16-2003 18:02:38
Thanks, Brent. I have since learned from the owner that it is a later model, probably near the end of production. I'll keep your address for any other questions. Thanks again.
