Lesser Known Classics Discussion Forum
Chainsaw Lombard help!
Roy Boucher
08-30-2003 09:49:45
I have a Lombard saw with these # 30-276 9,#137913
Ashland Mass.I need to know chain and bar size also what size file for chain.It says a #10 chain but can find no cross info.Do not know which of the numbers are model number and no one around here has any info,Need help please!
Daryl
08-30-2003 20:08:25
 Re: Chainsaw Lombard help! in reply to Roy Boucher, 08-30-2003 09:49:45
Roy,
I have an old Lombard chain saw and BOY does it have a big chain. I also have the original owner's manual and may have some of the information you need. I will check.
treeboy
08-30-2003 18:45:52
roy, 1st advice is to take the saw to a good dealer & fit a bar & chain to it... but i think the saw if its a bigger model had 404 chain .58 grove in the bar (some bars are stamped on the side) IF YA HAVE THE OLD BAR,,, THE CHAIN SHOULD have a code stamped into the dive links also..
with that old style clutch the chain will need to smoothly fit around the drive gear , check for excessive wear on the drive gear were the chain runs around it(outer clutch unit) on your saw it think...
