Lesser Known Classics Discussion Forum
Howard Terrier Rotary Hoe
Shane
09-14-2003 20:24:04
I have a Howard terrier walk behind rotary hoe that has a Howard engine bolted to it. I have only just bought it so I decided to change the oil and check the air filter. On checking the air filter the was no oil in it. If anyone out there is familiar with this engine could you please tell me where the two bits of mesh and the disk with a hole in it are supposed to fit and should the oil be filled up to the dimple in the side of the can on the air filter canister.
Thankyou for you time Regards,
Shane.
Rob Buchan
05-17-2004 17:59:38
 Re: Howard Terrier Rotary Hoe in reply to Shane, 09-14-2003 20:24:04
Shane,
I am looking at one to buy next week.
What is the market price.?
Thanks
Rob from Wangaratta, Vic
Brian
10-13-2003 01:26:34
According to my "L" series engine book:
1. Wash out the bowl with petrol
2. Remove the baffle and horsehair element
3. Thoroughly wash element in petrol
4. After drying it out, immerse in clean engine oil and thoroughly drain out all surplus oil before replacing.
5. Recharge the bowl with clean oil to the level indicated, and replace
The two bits of mesh fit either end of the horsehair filter element
The "disk with hole" is probably the Oil Deflecting Plate which fits between the body and the sump
Corin
11-29-2003 17:10:07
 Re: Re: Howard Terrier Rotary Hoe in reply to Brian, 10-13-2003 01:26:34
I have a fair few spares for Howard Terriers, and two restored units and one work in progress, if anyone needs anything feel free to contact me.
keith Batt
05-09-2006 14:08:49
 Re: Re: Re: Howard Terrier Rotary Hoe in reply to Corin, 11-29-2003 17:10:07
Do you have a source for tyres for the terrier?
Boynt
12-31-2004 23:47:17
I am requiring the 11 tooth selector gear that drives the hoe tynes from the right hand side of the machine from under the cover.
