Lesser Known Classics Discussion Forum
BF Avery Model A Carburetor
Chuck Murphy
09-26-2003 06:53:52
I need a carb for a BF Avery Model A. Looking for a Tillotson YC 10A. Have been unable to find anything on the internet so far and would appreciate some assistance.
Alberta Mike
09-27-2003 17:19:32
 Re: BF Avery Model A Carburetor in reply to Chuck Murphy, 09-26-2003 06:53:52
Keep in mind that almost "any" carb (make or model) will work if 1)the bolt-up flange is the correct size for the manifold, 2)the throttle linkage is on the correct side and opens/closes in the proper direction relative to the governor linkage. The choke setup is not as critical since there is a bit more flexibility to adapt something there. Even the throttle side/setup can be reversed with a bit of ingenuity and tinkering. A lot of Marvel Schebler carbs would work or could be adapted to work (and they are probably the most common make around).
