Lesser Known Classics Discussion Forum
Cockshutt 30 maintenance
ab ralph
10-19-2003 14:19:48
Anyone know the cross-over for the K55 oil filter that is used on the 30?
What gear oil I use in the transmission, Is the trans and dual range differnet or do they share they gear oil??
Kent
10-22-2003 10:36:10
 Re: Cockshutt 30 maintenance in reply to ab ralph, 10-19-2003 14:19:48
The NAPA # for the oil filter is: 1006 (SAE 30 oil for most weather) in crank case
SAE 90 extreme presure gear lub(for transmission)
the transmission uses 5 gallons, the low/high range cavity is suposed to be filled by splash from the main transmission case. My manual says not to use the low gear till you have operated the tractor for an hour or so, giving the "splash time to fill this cavity. The pulley housing needs 2 gallons of SAE 90 and is a separate area. There are 3 drain plugs one for the main transmission, one oposite the creeper gear lever, and the one for the pulley housing, which is located just in front of the above mentioned plug. Hope this helps.
