Lesser Known Classics Discussion Forum
1988 Ford 755B Backhoe/Black Smoke
Terry Miller
10-25-2003 17:19:50
Can someone tell me what would be causing this backhoe to run hot and blow black smoke? In addition to this problem it is leaking oil from the head gasket and valve cover gasket areas.
Mike
11-04-2003 17:08:38
 Re: 1988 Ford 755B Backhoe/Black Smoke in reply to Terry Miller, 10-25-2003 17:19:50
have you check air filter? a plugged air filter can cause a diesel to smoke--had a skidsteer with perkins once and that happened evertime it was time to change the filter--along with running erratic. Air filter okay? make sure if you have a hose coming from filter to intake that it is not collapsed
Terry
11-05-2003 17:13:39
 Re: Re: 1988 Ford 755B Backhoe/Black Smoke in reply to Mike, 11-04-2003 17:08:38
Mike, Thanks, I did check this out first but no luck.
