Lesser Known Classics Discussion Forum
Long 460? steering pump
Dan C
11-01-2003 17:46:26
Well, one step forward and two back. Seems that the crank case is filling up with oil from the steering hyd oil. Is there a seal that will cause this. no oil leaks but the oil dissappears the next day and into the crankcase. Have you heard of this before? The three point is finally working great. Seems also I have a bad injector wonder where I might be able to get one.
Jason
11-02-2003 15:35:40
 Re: Long 460? steering pump in reply to Dan C, 11-01-2003 17:46:26
There is a shaft seal in the pump that is leaking but the main reason for this seal to leak is you have a blown high pressure seal inside the pump. Just go to your local dealer and get a seal kit you can rebuild it yourself really easy pump just make sure you look good at how the parts come out and put the new parts in
