Lesser Known Classics Discussion Forum
562 belarus water pump
david
11-03-2003 15:23:59
water pump started leaking out the weep hole so I got another pump but the place where the 3/4 hose attaches isnt in the same place. when you put the pulley on and tighten the nut the pump locks down.whats wrong? the impeller pulls down against the housing.the engine# is 629869,the serail # is 255906. the pump # is wp-1022 and then A-2401307010A03 its an A&I number. Any help is appreicated. Thanks, David
