Lesser Known Classics Discussion Forum
Avery V Rear Wheels
Justin
11-24-2003 20:47:32
Hello, I am needing new Rear Rims for my Avery V, it has the Pressed Steel type on it. Can anyone tell me what other rims from other applications or tractors will fit?? I would like to buy Brand new ones but would accept good used ones. Anyone out there have a set New or Used for sale?? They are 24" rims. I have brand new Firestone tires to put on them that I got for my 8th grade graduation. Any Help Appreciated. Thanks Justin....
Alberta Mike
11-28-2003 09:37:02
 Re: Avery V Rear Wheels in reply to Justin, 11-24-2003 20:47:32
Any tractor with those dropped gear reduction axles (I think your Avery has those) has a possibility of rim lugs hitting the wheel axle castings. You just never know for sure until you get them on. On my Avery for example, the rims do fit on the hubs but only in one position of the many variations that are used for changine rear tire width. The reason is that my mounting lugs on the rims hit the axle housings in certain combinations with the hub.
Gene Davis (GA.)
11-26-2003 20:05:38
Think the rims from a Farmall Cub are about the same style, check them out. Gene
