Lesser Known Classics Discussion Forum
Belarus hyd down pressure
Alvin n Ms.
01-14-2004 16:56:23
On subject of Belarus down pressure, do they always apply pressure when lowering,or is there also a setting similar to "Float" ? It seems like constant down pressure on the 3 point would be a pain at times. I have never run a Belarus. Thanks
Richard
01-25-2004 14:59:21
 Re: Belarus hyd down pressure in reply to Alvin n Ms., 01-14-2004 16:56:23
Thre is a float position on the 3 point aswell as the remotes
Ron_NY
01-22-2004 14:46:15
I own a 1990 Belarus 525 (approx 65HP). The height of the 3 point hitch is set via a hydraulic lever, just as moving the front end loader up and down. As you can lift the front end of the tractor with the bucket, you can lift the rear end into the air by pushing an implement down.
