Lesser Known Classics Discussion Forum
Deutz 5506 Brakes
Spring Green
01-20-2004 19:21:12
Anyone have any experience with the rear brakes on a Deutz 5506? Mine don't work worth a darn. Plenty of pedal, but no stopping. I have pulled the drums and everything was like new. Plenty of lining left and the brakes were adjusted correctly. All the hardware is in very good condition and there is no oil on the lining. Shoe outside radius fits the drum inside radius very well. Is this something inherent in this tractor or do I have hard or glazed lining? Any easy fixes? Can't be too much to go wrong, just a cam and drum and lining. Hand brake works great, but that's a separate brake.
Robert in W. Mi
02-14-2004 07:32:07
 Re: Deutz 5506 Brakes in reply to Spring Green, 01-20-2004 19:21:12
The problem is, the tractors came from the factory with "too hard" of lineing material! Have your shoes relined with softer material, and you will have the problem fixed!
Robert
Spring Green
02-24-2004 16:52:44
 Re: Re: Deutz 5506 Brakes in reply to Robert in W. Mi, 02-14-2004 07:32:07
That is what I suspected. Everything looks like new and there is no sign of oil or grease on the lining that I can see. Thanks for the advice.
Kurt
01-28-2004 16:54:32
Are they Hydraulic or manual brakes? If they are hydraulic, check to make sure the wheel cylinder is not set up and then make sure you bleed them properly. Also, adjustment is critical, you should tighten the adjusters so there is a slight drag when you spin the wheel. If they are manual, I have no idea.
Good luck,
Kurt
goofus fr L.A.
01-28-2004 07:25:38
The shoes must have been saturated in oil. You can clean them with anything known to man, then boil them in detergent for two days, and they will never hold again. I have been there and tried. goof
