Lesser Known Classics Discussion Forum
Deutz-Allis 7110
Andy
02-15-2004 14:13:34
I am looking for some information on how the speed of the cooling fan is controlled. In cold weather it blows all of the time. I also run a 7120 on which the fan does not turn until the engine warms up. I am aware of a sensor that mounts to the exhaust manifold that must meter oil to the fan. Does anybody have experience with this?
Dave
04-30-2004 20:57:15
 Re: Deutz-Allis 7110 in reply to Andy, 02-15-2004 14:13:34
These tractors have a thermostat that controls flow of oil to the fan. If the thermostat goes out it's possible to supply oil to the fan by placing a thin washer on the spring pin valve that the thermostat would normally depress. You should not screw the pin valve in to the oil supply line without a washer because the pin may break off. Perhaps this was done to your tractor. I was told a new thermostat is over $500 so the washer trick may have been used.
Andy
05-06-2004 06:48:07
 Re: Re: Deutz-Allis 7110 in reply to Dave, 04-30-2004 20:57:15
Thanks Dave. I don't know the full history of this tractor but what you describe sounds possible.
If I could pick your brain further. There is a solenoid valve in the oil line leading to the fan between the thermostat and the fan. Do you know anything about that?
don
03-23-2004 18:31:22
Call Rusty @ Ward Bros he can help you with this fan
Andy
03-27-2004 19:09:31
 Re: Re: Deutz-Allis 7110 in reply to don, 03-23-2004 18:31:22
Don,
Thanks for the advice. I'm not familiar with Rusty at Ward Bros and don't know how to contact him. Thanks for any additional info.
