Lesser Known Classics Discussion Forum
schramm backhoe/loader with compressor
charles davis
02-17-2004 04:10:38
looking for any literature, specs, etc
info on the starter
compressor side works (seems To) but can't get the engine to start, has spark, compression
6 cyl gas engine, (3 cyl compressor, 3 cyl engine)
ant info would be greatly appreciated
thanks
R. Fenton
08-21-2006 07:57:45
 Re: schramm backhoe/loader with compressor in reply to charles davis, 02-17-2004 04:10:38
Charles,
I am the (proud?) owner of a similar Schramm backhoe/compressor and in need of some parts. Do you still have it? If so, where is it located? (I'm in SW Ohio) Thanks, Ron
tim vogel
11-13-2006 19:10:50
 Re: schramm backhoe/loader with compressor in reply to R. Fenton, 08-21-2006 07:57:45
I have a 1954 schramm backhoe/compressor, with manuals and parts list. I live in six lakes mi. It is in good running and working condition,,In need of a good paint job..
Ron Fenton
03-17-2007 18:44:07
 Re: schramm backhoe/loader with compressor in reply to tim vogel, 11-13-2006 19:10:50
Well, the old Schramm finally gave up the ghost - cylinder #2 swallowed a valve so I'm either looking to replace the engine with a straight-6 or left to find an old IH 504 engine to stick in there. Ideas anyone? Ron
Peter Marsters
04-09-2007 13:18:32
 Re: schramm backhoe/loader with compressor in reply to Ron Fenton, 03-17-2007 18:44:07
Ron, I have a similar machine to what you have- 1yd. loader/hoe with compressor, 12 volt. I was searching
the net to see what options I might have to sell
it and came accross your posting.. It is fully functional. If you have not resolved the problem with your machine and are interested in a whole
machine let me know. Otherwise, good luck with
your machine. Peter
Ron Fenton
04-09-2007 14:11:53
 Re: schramm backhoe/loader with compressor in reply to Peter Marsters, 04-09-2007 13:18:32
Peter,
May I inquire where the B/H is located and how much you are asking for it? I'm seeing Inline-6 engines going for $50 or even less on Craigslist occasionally, but I suspect the modification wouldn't be much fun.
If the distance isn't too prohibitive (I'm in S.W. Ohio) it sure would be nice to have a running tractor with spare parts for a change!
Ron
charles davis
08-18-2007 04:32:35
 Re: schramm backhoe/loader with compressor in reply to Ron Fenton, 04-09-2007 14:11:53
i have a schramm backhoe/loader which has served me well for 4 years but have recently broke a rear axle.
Anyone out there have any leads on partsfor these?
thanks for any help
tim vogel
05-14-2007 16:26:31
I have done a couple of projects with my Schramm B/H and will be selling it . $2800.00. Runs and works fine. could use a paint job .. I am located in central part of Michigan.
