Lesser Known Classics Discussion Forum
Antique air compressor
Stacy
02-19-2004 19:09:06
any one have info on an air compressor made by United States Air Compressor Co. out of Cleveland OH. wondering when it was made and value if possible. thanks in advance.
Alex
04-15-2004 21:17:26
 Re: Antique air compressor in reply to Stacy, 02-19-2004 19:09:06
well i dont know if i have a compressor built by this company,but i found a small compressor in my grandpa's shed.it is a very small in-line 4 cylinder compressor with a cast iron block,aluminum head,valve cover, and oil pan.its measurements are 7" long,6 5/8" tall,2 1/8" wide at head,3 1/2 wide at oil pan,and the crank is 9 1/2" long.it has two intake and one exhaust port.for the intake, it has vacuum operated valves and for the exhaust,it has these ball valves that are operated by the pressure comimg out.it has ten head bolts,eight oil pan bolts, and two valve cover bolts.it has no makings that i can see but if you have and info, let me know.thanks.
