Lesser Known Classics Discussion Forum
British Leyland Tractor ID
Jim Polanosky
03-04-2004 08:00:29
A friend of mine has a British Leyland Diesel tractor & I'm trying to help her identify the model number - I've not been successful in locating any serial plates, etc. on it yet.
It's a 4-cyl Diesel with a SIMMS injector pump - I'm gonna guess 50-70 HP range.
I've done some research on the Web but have not been real successful in finding any detailed info that would help with identification.
Can anyone out there provide any information on where to look for the Serial Plate, or to Websites that may have what I'm looking for?
Thanks for your time!!
Fighting suburbia in NC
03-18-2004 06:21:38
 Re: British Leyland Tractor ID in reply to Jim Polanosky, 03-04-2004 08:00:29
There is a vin tag on the top of the driver side frame rail mid-motor that should give you model and serial number info. There is a stamp on the right rear corner of the head outside of the valve cover that will tell you which motor is in it. It is kinda hard to see without a good cleaning and a flashlight and mirror. Depending on motor it can be anywhere from 35-70 HP. If it is a 4/98-NT, -DT, or -TT motor then it is the 70-75 HP range. These are powerful midweight tractors that have a number of amenities such as remote hydraulics, independent PTO, power steering, and diff lock. They are good on fuel, too.
Jim Polanosky
03-22-2004 13:29:34
 Re: Re: British Leyland Tractor ID in reply to Fighting suburbia in NC, 03-18-2004 06:21:38
Thanks for your help! The VIN tag was right where you indicated, except buried under years of accumulated crud!
The unit is a Model 384, S/N 84N / 302488 / 149972. Are you familiar with this model? I haven't tried firing it up yet due to other workloads, but maybe this coming weekend.
Thanks again!
Jim P.
Roy in UK
03-04-2004 14:31:19
Maybe these guys could help
Jim Polanosky
03-04-2004 18:29:28
 Re: Re: British Leyland Tractor ID in reply to Roy in UK, 03-04-2004 14:31:19
Thanks very much for the link! I'll contact them right away!
