Lesser Known Classics Discussion Forum
wisconson TJD engine
benjy bertossi
04-09-2004 16:33:03
Looking for info on two cylinder Wisconson TJD. Recently ovehauled, lots of gear noise from govenor. Is this normal? Detailed tech information needed, would appreciate information on sources of tech info.
Larry from MD
04-10-2004 09:21:17
 Re: wisconson TJD engine in reply to benjy bertossi, 04-09-2004 16:33:03
No its not normal.Goveners flying apart on engines with lots of hours does happen.You should look into this before running the engine.The timeing gears can be chewed up if the gov sticks and thats a big expencive repair.The parts are probably spinning around inside right now.
