Lesser Known Classics Discussion Forum
IMT 539 hydraulic problem
Clif Jensen
05-17-2004 16:39:39
3 point lift has been loosing strength over several years. First showed up by loosing lift power in hot conditions. More recently, high rpm needed to lift bush hog. Now, hardly lifts at all. Sometimes high rpm will do it, other times...nothing. Oil changed...same performance.
suspect bad pump or lift control valve. If problem is bad pump, how to repair? Manual is hard to follow.
