Lesser Known Classics Discussion Forum
4 cyl 2 plug per cyl FUNK head ??
Joel G. washi
06-06-2004 21:57:12
sory if my messages have doubled up but my pc crashed and i dont know what all went out. I have a alumanum 4 cyl 2 spark plug per cyl head that fits perfectly on a model A ford even the steam holes on the gasket line up. it has FUNK cast on the rear side. on the top it has heat treated--110-- and it looks like zyolit. it does not have the water outlet like the A ford it has outlet hole with bolt holes.not unlike a model T ford. it has a distributer mount boss and three 5/16 studs sticking up to mount mag/ dist. the distributer hole lines up perfectly
?#1what mag did they use/ dist. ?#2 what water pump thanks alot Joel & ajack ( ajack is a 1928 ford todor) tbcjoelnicky@aol.com ps the spark plug # champion C7 all 8 of them
Dsl
06-19-2004 17:26:04
 Re: 4 cyl 2 plug per cyl FUNK head ?? in reply to Joel G. washing state, 06-06-2004 21:57:12
My guess is the same as the others: from a Funk airplane engine, as aircraft often had dual ignition systems for safety. That head could be worth some serious dollars to the right aviation restoration buff.
Bus Driver
06-14-2004 16:58:16
My guess is that the engine had two separate ignition systems for safety reasons, if one failed the engine kept running. Magnetos would be lighter than battery systems. Magneto would eliminate the battery and generator which in turn would eliminate the starter.
Joel
06-09-2004 10:55:49
tHANKS TO WILLIAM G YOU ARE CORRECT i HAVE A SITE ON FORD POWERD AIRPLAINS ALL I HAVE TO DO IS FIND IT. THE FACT IS I HAVE A FRIEND THAT HAS A MODEL a WATER PUMP ON HIS CAR (1930 FORD). i WILL POST THE SITE ADD. AS SOON AS I FIND IT. THANKS ANY MORE INFO WOULD BE GREAT THANKS jOEL
William G
06-08-2004 03:59:22
The Funk Bros built airplanes before they went into the tractor retrofit line. If my memory serves me correctly, sometimes it doesn't, their early planes were powered by a Funk modified A or B engine. Visit you local airport and see if there's an EAA Chapter there. Those guys can hook you up with more info. I'll bet there's someone building a Pietenpol parasol wing homebuilt with a Model A block looking for that head.
Joel G
06-09-2004 12:04:11
 Re: Re: 4 cyl 2 plug per cyl FUNK head ?? in reply to William G, 06-08-2004 03:59:22
William G. what I ment to say was my friend has a modelA ford with a airplane water pump. thank you Joel G.
