Lesser Known Classics Discussion Forum
Belarus 250AS help
Rick Bales
07-31-2004 17:45:10
I know this tractor has a bad rep but if any of you have any real experience with one, I could use a a bit of advice. I use this tractor to mow my yard, 7 acres. That's it. I have had what I thought was an exhaust leak for some time and it is getting worse. I pulled the exhaust manifold and guess what? That's not it. I have exhaust coming from the space between the intake and exhaust on the front jug. It is loud and blows a good bit of smoke at start up. So do I have a cracked head? What will happen if I keep running it?
This is a basic tractor but it shifts fine and the PTO works. It does what I need.
Thanks in advance
Rick
Trkr
08-09-2004 12:27:07
 Re: Belarus 250AS help in reply to Rick Bales, 07-31-2004 17:45:10
Head studs are loose(4).Pull the little valve cover off youll see them all.
richard
08-07-2004 10:03:38
Most likly blowing from head/cylinder joint,nip the bolts up a bit,i dont remember if those engines ever had a gasket,we only sold a handfull.
rick bales
08-09-2004 19:48:00
 Re: Belarus 250AS help in reply to richard, 08-07-2004 10:03:38
Thanks guys it is running better now. Tourqed the bolts to 80lbs and tightened the injector.
