Lesser Known Classics Discussion Forum
American Tractor Corp. Terratrac GT-25 or GT-30
B Dutton
08-02-2004 08:10:00
I have just inherited an ATC Terratrac crawler either a GT-25 or GT30 not sure how to tell. SN 6319. It needs and engine rebuild. - would anyone know the engine manufacture and or where a person could get parts or a rebuilt engine?
From further research it sounds like the engine may be a Continental F140 Flathead 4 cyl.
Does anyone have any information on this crawler tractor?
Mark Costello
08-22-2006 03:50:02
 Re: American Tractor Corp. Terratrac GT-25 or GT-3 in reply to B Dutton, 08-02-2004 08:10:00
Hey I am in kind of the same boat. I have a Model 500 Terra Trac that is humming in 1st and reverse. I just got shaft A off and the gears look to be in pretty good shape. However, I had thought this humming was a bearing problem, and the rear bearing had been heated at one point. Also, the rear bearing has a different make outer race, then the bearing itself. After taking the driveshaft of it was apparent that shaft A was sloppy, which is why I went ahead with this operation. So now I was wondering if I could locate a shaft, gears, spacer, and bearings and be done with the whole thing. Any help would be appreciated.
Marcel V
03-07-2006 06:45:19
my dad has just gotten a terra trac from my uncle who bought and used it for parts for a case 310 dozer that we also have (bought form my uncle also) now we want to put the terrtrac back together and we have most of the parts for it and we dont have any books or nothing on it were not even sure what model it is. its got a forklift on the front we no its got a conetial motor in it and i found the tag on it but at the moment i dont remeber the model number. so if any one has any info please send me something about.
george md
08-02-2004 22:29:49
B Dutton,
Serial # , according to Edward's list in
the files section of the case terratrac group,
says it is a GT-25 == 1951. Check your yahoo mail , you are a member.See
you there . I can get you most engine parts delivered to your door.
george
