Lesser Known Classics Discussion Forum
loader for long 610
cdv
08-12-2004 19:03:48
any one know what loader fits a Long 610 4wd or were I can buy a good used one thanks cdv
Bus Driver
08-13-2004 16:40:50
 Re: loader for long 610 in reply to cdv, 08-12-2004 19:03:48
Dunham-Lehr loaders fit many models of tractors.
geok
08-12-2004 20:07:14
I forgot to mentioned wide enough to fit outside your tractors sheet metal but narrow enough to clear your front tires.
geok
08-12-2004 20:03:17
Most any loader will work that is within your hp range and that main frame of the loader is wide enough to fit out side your tractors sheet metal.
I would avoid mid mount style unless it has a sub frame that bolts up to the rear axle.
I mounted several brands to a Long including a Davis and a later model industrial Massey Ferguson loader. They both may have been made in the same factory since MF bought out Davis.
Some of the other brands beside Long, were Bushog (similar to long) Koyker, westerndorf and ezeeon.
