Lesser Known Classics Discussion Forum
Holder A16 Cultitrac
Shane Atkinson
08-15-2004 21:53:58
Hi all, I have recently aquired a Holder A16 Cultitrac after my father passing away. I have not been able to find out any info on this tractor. The manuals that I have are for the A15 and I read somewhere that the A15 was air cooled and the tractor I have definitely has a radiator. It has the two stroke diesel motor, is articulated in the middle, is 4 wheel drive and has 6x16 tyres with white rims (as per the A18). Any information would be much appreciated.
Bernhard
08-17-2004 01:24:15
 Re: Holder A16 Cultitrac in reply to Shane Atkinson, 08-15-2004 21:53:58
I´m not really sure, if it has a Sachs 2stroke Diesel...onliest Info I have is about the AM 2 Cultitrac, 18 hp 2cyl. watercooled.But this should be the same tractor only 2 hp less. Some Sachs Diesels had been aircooled, some watercooled. Could be possible that there is a MWM engine in it. Only newer ones had a Lombardini.
Bernhard
08-17-2004 01:10:28
www.holderfreunde.de...there should be someone be able to answer You...even in english
