Lesser Known Classics Discussion Forum
bush hog size for long 445
wvbill
09-06-2004 05:27:48
what is best size bush hog for 445 long,,my 4ft is for sure on the small size. thanks
Marty g.
09-07-2004 04:51:13
 EXTRA LARGE! in reply to wvbill, 09-06-2004 05:27:48
Jokes asides.
Go as wide as the outside of your tires if you want to work aound trees.
Jim in NC
09-06-2004 18:07:08
 Re: bush hog size for long 445 in reply to wvbill, 09-06-2004 05:27:48
Your 445 will handle a 6 footer ok. If you have alot of narrow areas, trees, or buildings to work around, I suggest you use a smaller one because you can mow any place that you can drive your tractor. I use a 4 and a 5 footer behind mine and also mow some large fields that are not too rough. I just go up to a higher gear and go faster to make up for using a smaller machine. Good Luck!
Bobby in VA
09-28-2004 07:46:59
 Re: bush hog size for long 445 in reply to Jim in NC, 09-06-2004 18:07:08
I have a heavy duty 5' with 90 HP gearbox.
It is all the 445 wants without adding weight
to the front end if the area is hilly (front
end begins to bounce and lack steering going
uphill)
Jim in NC: do you know any junk yards with 445's in NC???
thanks
geok
09-06-2004 07:30:30
Tractor can handle 6 ft. cutters with 45 hp gearboxes.
