Lesser Known Classics Discussion Forum
BF Avery V help!
MM_TX
09-14-2004 14:08:30
I have a chance to get one pretty cheap and am doing homework before I have even seen pix. It is supposed to be complete, streight tin and probably stuck. Do all the Avery Vs have a PTO. Do any have hydraulics and rockshaft? Can you find parts? Are parts expensive because they are not as common as a Cub? None of the pix I have seen have any equipment with them. I guess to put a belly mower on one you would have to modify brackets. Where can you find Info on these tractors? Thanks for any help.
Chuck
09-17-2004 15:47:09
 Re: BF Avery V help! in reply to MM_TX, 09-14-2004 14:08:30
Check out this website
www.horizonview.net/~kault195
Last pic of V is mine. Email me and I'll try to answer your questions.
Alberta Mike
09-16-2004 05:47:31
There is a little article in the "articles" section here in the left margin on B F Avery history (it's still in the list of new articles there at the start). Not much on the V but it gives some history of the company and also lists the website that the fellow below mentioned. There is an Avery book on the market now as well, it is advertised in the Antique Power Magazine.
Larry from MD
09-15-2004 09:08:02
Moline bought out avery in the 50's,so most people use that board for info on a V.There is allso a website kallt something.
