Lesser Known Classics Discussion Forum
b f avery a generator wiring
Charley Arms
09-16-2004 06:26:33
i am having trouble wiring my generator the bearings were replaced and the generator was bench tested and proved to be good
the original light switch/regulator has been changed
my tractor is a 1949 model a the generator came off a 1950 model r but the numbers match those in the book
the tractor had an alternator on it when i got it and is currently still on it however i would like to go back to the generator to be more original
the system has also been changed to a negative ground instead of the original positive ground
i have tried a 3 way light switch but can't get the system to charge and it also has a heavy current draw at all times
if anyone can help i would appreciate it
Carl Finley
10-28-2004 20:56:55
 Re: b f avery a generator wiring in reply to Charley Arms, 09-16-2004 06:26:33
you don't need to hook up a three way switch on your tractor, you should have a positive wire comming from your generator and that goes to your ameter gauge and you should be able to ground it just about any place and if you no how to use a meter might help you as I can do this kinda stuff in the dark. I have redone many of tractors and I guess the more that you do the better you get at it. I don't no if you have a regulator on your generator if so you might get confused. good luck and just hang in there till you have it done Carl Finley
Keith Ault
09-16-2004 21:16:39
send mail address and I will send a wiring diagram good luck
Steve Morgan
03-04-2006 06:17:47
 Re: b f avery a generator wiring in reply to Keith Ault, 09-16-2004 21:16:39
Hello,
I have also been trying to locate a wiring diagram for a BF Avery A or R series. I do have a BF G -MM series wiring diagram that is close, but not exactly like the original wiring setup. I was hoping I could also acquire the wiring diagram that has been posted in this series for the BF Avery A or R. Thank you very, very much!!!
Steve Morgan
4419 Lexington Drive
Pleasant Hill, IA 50327
Ernie Coulter
10-02-2004 08:13:55
I also have a Avery R without any wiring, this tractor has been sitting for 20 years. Do you have a diagram for this one. thanks
Ernie Coulter
1190 Goggin Lane
Danville Kentucky 40422
charley arms
09-17-2004 05:40:50
i have a wiring diagram in my manual but i am having trouble finding a switch/regulator like the diagram shows
however yours might be better so send it
676 salem ridge rd.
clarksville, tn 37040
thanks for your help
John F in MD
09-16-2004 19:52:18
I don't see why you can't use a Farmall Cub wiring diagram. Here's a link that shows the wiring for early Cubs with the 3rd brush gen with the hi/lo/headlight switch and the later Cubs with a std generator. Good luck.
Link
