Lesser Known Classics Discussion Forum
Nuffield 460 - How to pull engine?
D. Caldwell
09-26-2004 06:36:32
I have a Nuffield 460 with a seized engine. I am in the process of pulling the engine, and have all the motor mount bolts out etc. I can lift the front of the engine a couple of inches, but can't seem to separate it from the transmission housing. Is there a step here I am forgetting or do I need to remove the transmission housing as well? Any suggestions appreciated.
Thanks.
Dan Caldwell
Chatsworth, Ontario, Canada
Lyn Jones
09-26-2004 13:36:32
 Re: Nuffield 460 - How to pull engine? in reply to D. Caldwell, 09-26-2004 06:36:32
There are a series of bolts which hold the engine to the transmission housing. These will need to be removed. You will also need to remove the steering wheel and the gas tank Then remove the steering box assembly which will give you access to the clutch. Remove the two pins which locate the sleeve which conects the clutch shaft to the tranny and slide this back along the shaft. Now you should be in a position to lift the engine.
Good luck.
