Lesser Known Classics Discussion Forum
Holder in Oregon
Wallace Skyrman
12-30-2004 18:04:04
20+ Years ago I had a AG-3 Holder. It was "found" on a dealers back lot having failed after a $3000 no guarantee overhaul. I bought it from the owner and discovered that a rod bearing had failed. Could not get any response from the folks that had earlier supplied a new built up crankshaft, bearings and pistons. So I rebabbited the failed rod insert, bench tested the special oil feed pump and started it up. It ran fine but a letter I received from the new Canadian distributor had me worried. (1980) "---Even motors rebuilt at the factory by specialists are unsuccessful and have a life expectancy of between 10 minutes and 200 hours. Holder now sells a 4 stroke replacement for the 2 stroke dry sump engines---" I sold the tractor after two years of use warning the new owner about the problem. In another couple of years he had the same problem. I heard a retired German machinist had it running again.. wallysky@charter.net (Remove the y before sending)
