Lesser Known Classics Discussion Forum
350 Long
Rick Cromer
04-07-2005 20:18:49
1979 350 Long....Have replaced all wiring, new alternator, new battery. Obtained warning light relay today; because the alternator was not charging battery....alternator light remained on. Replaced relay and started tractor; light was off but just a few seconds after starting tractor there was a pop and smoke rose from near relay. Tractor runs great but alternator will not charge battery, so it must be charged after each use. Wiring problem??? Any ideas...totally in the dark.
Bus Driver
04-14-2005 16:28:50
 Re: 350 Long in reply to Rick Cromer, 04-07-2005 20:18:49
Did you replace the voltage regulator? It is low cost, a separate unit from the alternator.
