Lesser Known Classics Discussion Forum
1984 zetor 5245 brakes
werty
05-05-2005 12:20:48
Having a brake problem with my 5245. there is a reservoir in the back of the engine compartment closest to the steering wheel that is empty. does anyone know if this is for brake fluid and what type is used. It seems like a bad master cylinder(the pedal just goes to the floor) but I"m hoping to get lucky and just have to add fluid and maybe bleed the system. any help would be appreciated-thanks
Unimog
05-05-2005 19:17:24
 Re: 1984 zetor 5245 brakes in reply to werty, 05-05-2005 12:20:48
That"s the fill reserve for the brakes and the
clutch system too. You can use regular DOT 3
fluid and should bleed the system if the tank
reservoir was completely emptied. There are two
master brake cyls., one for each pedal. Clutch
master is the same as brakes cyls.
werty
05-06-2005 10:51:41
 Re: 1984 zetor 5245 brakes in reply to Unimog, 05-05-2005 19:17:24
Unimog- thank you for your help!
