Lesser Known Classics Discussion Forum
Deutz 4006 hydraulic lift
jt_44
06-04-2005 08:55:57
Hi,
Does anyone knows how the control unit for hydraulic power lift is attached in Deutz 4006 tractor ? My problem is the lift, which goes up and down, when there is load on it. The cylinder is OK, so I would like to change or repair the control unit (valve).
Jim Warren
09-29-2005 09:20:08
 Re: Deutz 4006 hydraulic lift in reply to jt_44, 06-04-2005 08:55:57
Yes, the control valve in held in its bore by screw behind the remote valve or the block where a valve would be. This is a hollow screw thru which the oil flows. With screw out and valve detached from rear and front, turn 1/4 turn cloclwise. This lets the o-ring over the hole slide forward withpout damage. With valve out =, examine check valve. [ball and spring] the seat of the ball will be worn and must be replaced or can be re-surfaced with properly shaped tool and grinding compound. If you get this far, e-mail for more help.
Robert in W. Mi.
06-07-2005 14:30:30
There's a valve in the rear end of the tractor that causes the junping up and down of the 3 point when that valve goes bad.
You can replace it from the outside, but you have to know the procedure, and it's been so long since i've done it i've forgot how to do it.
Seems like last time i saw the price on the valve it was many years ago and it was about $350.00 then???
This place did one for me one time long ago. 231-924-3420 They are in west Michigan.
Robert
jt_44
06-09-2005 06:49:37
 Re: Deutz 4006 hydraulic lift in reply to Robert in W. Mi., 06-07-2005 14:30:30
Thanks Robert,
it was just that procedure I was hoping someone to know. If anyone have repair manual for 4006 it is most likely described there.
There is three or four bolts in front of valve. but opening them doesn't loose the valve.
Robert in W. Mi.
06-09-2005 17:18:08
 Re: Deutz 4006 hydraulic lift in reply to jt_44, 06-09-2005 06:49:37
All i remember is, that you have to reach in and turn the valve a certain way to get it out... Wish i could remember more, but it was LONG ago since i did it!
Robert
jt_44
06-14-2005 07:23:35
 Re: Deutz 4006 hydraulic lift in reply to Robert in W. Mi., 06-09-2005 17:18:08
I got a spare part list for Deutz and it seems that there could be a screw right side of power liftīs body holding the valve. However i canīt find it from tractor. Could it be under the extra hydraulic valve, which is also right side and front of hydraulic block ?
I could sent a picture from spare part list, if there would be a place to put it.
-jt
Robert in W. Mi.
06-15-2005 20:07:06
 Re: Deutz 4006 hydraulic lift in reply to jt_44, 06-14-2005 07:23:35
Sorry, i just don't remember how i did it, it was too long ago!!
Call Peter at 231-924-3420 I know they have replaced them in there shop. He may ? beable to help you.
Robert
