Lesser Known Classics Discussion Forum
3 wheel silver king width
egg
08-10-2005 19:43:04
i would like to find out what a 1937 silver king width of a 3 wheeler thanks
Larry from MD
08-11-2005 09:25:13
 Re: 3 wheel silver king width in reply to egg, 08-10-2005 19:43:04
I have one ,but don't remember the outside width.Its an r66 and it has 2inch spacers on each side,they were outside and i added 2 inches to the rims and had to put them inside.My old trailer with bed between the wheel had the rims forced and rubbing inside the rails.So i added a board outside the rails on one side for one wheel to sit on.
earthmasterk
08-11-2005 08:45:30
The older Silver King tractor models used the tread width of the rear tires as the model number.
The 3 wheelers had 3 tread widths. 60 66 72.
Also there was a letter before the serial number. The letter would be a R for rubber or S for steel.
So, you could have a R60 R66 or R72.
Later ones used 3 numbers (600 660 or 720) with the R or S letter before it.
Hope this helps.
egg
08-11-2005 10:06:07
 Re: 3 wheel silver king width in reply to earthmasterk, 08-11-2005 08:45:30
Thank you
Larry from MD
08-11-2005 11:55:12
 Re: 3 wheel silver king width in reply to egg, 08-11-2005 10:06:07
I measured mine right now the outside of the wheel is 79 inches.If the spacers were not on it would be 75 inches.
