Lesser Known Classics Discussion Forum
FLAT HEAD BUDA ENGINE
BART HAVENS
09-04-2005 19:07:57
I HAVE A OLD FLAT HEAD BUDA ENGINE HP351 6 CYC..
I GET ALOT OF BUBBLES IN THE RADITOR.NO OIL IN THE
RADITOR. THERE IS NO THERMOPSTAT IN AT THIS TIME.
DO I HAVE A COMPRESSION LEAK OR ARE THE BUBBLES BECAUSE OF NO THERMOSTAT. COMPRESSION IS 110-110-92-95-90-90 .
ANY IDEAS ?
BART
george md
09-04-2005 21:44:00
 Re: FLAT HEAD BUDA ENGINE in reply to BART HAVENS, 09-04-2005 19:07:57
Bart, Before you tear into anything serious, slip
the water pump belt off and see if you still
have the bubbles. If the bubbles are still there
most likely you have a compression leak,but if
they quit most likely you have a water pump seal
leaking air in while engine is running. Many times
the seal will leak air in for quite a while before
it leaks water out .
george
