Lesser Known Classics Discussion Forum
Belarus 250A
tim fadler
09-09-2005 08:40:56
I have an older Belarus 250A. Just recently got this tractor. I finally got the engine running,
however I can't seem to get it in gear. The clutch on the left goes down but the shifter on the left does not seem to be moving the gears in
order for them to take hold. The center gear shift does seem to move and take hold but does not
shift easily. Any comments are welcome.
Michael D.
09-09-2005 23:58:36
 Re: Belarus 250A in reply to tim fadler, 09-09-2005 08:40:56
I have just got ours going. I to had the same problem and had to play around with it for a while. You have to first set it in hi or low range. That is done by shifting the locker at the top of the shift pattern, then you should be able to shift it in to a gear. If you need email me and I will send you a copy of that page in the manual. I also have found a reasonable parts place that wont break the bank! Good luck!
