Lesser Known Classics Discussion Forum
age of hercules engine
big H
10-06-2005 16:37:16
I have a hercules Ixa-3x4 serial number 662075 I am trying to date the age of the tractor that this motor is in, I was told that this was the original motor that came in it. any help appreciated
big h
10-24-2005 18:27:32
 Re: age of hercules engine in reply to big H, 10-06-2005 16:37:16
The engine has 27001D with a F under that on the right side above the pan on the block. this is in front of the engine tag that gives Ixa and bore any help appreciated. harold
Larry from MD
10-07-2005 08:53:07
Most of those engines have a casting date on the right side just above the oil pan.sometime in the 40's the date was moved up to a raised pad just a little higher on the engine.On the old ones the the day and month may be reversed in order.
Larry from MD
10-07-2005 15:32:15
 Re: age of hercules engine in reply to Larry from MD, 10-07-2005 08:53:07
Some tractor companys used to like to claim it was thier engine,so on those the casting marks are gone.
