Lesser Known Classics Discussion Forum
Questions about the Cletrac General
Centaur Nut
10-17-2005 18:50:37
I just brought mine home and need to contact someone else who has one. For some unknown reason somebody has shortened the frame on mine between the motor & rear end, and I need to know how long it's supposed to be. Also, the ser. number plate is gone. Is there any other numbers I can use to i.d. this critter?
Tom Pal
10-30-2005 18:31:41
 Re: Questions about the Cletrac General in reply to Centaur Nut, 10-17-2005 18:50:37
if the id plate on the rear of the right side frame rail is missing, the only other numbers would be the casting numbers on the right side front of the engine block which will at least let you know how old the engine is and if its original.
Steve Schantz
10-25-2005 17:07:32
the rails on the General are 75 1/2 "
Centaur Nut
11-03-2005 19:44:54
 Re: Questions about the Cletrac General in reply to Steve Schantz, 10-25-2005 17:07:32
Thanks, mine has been shortened 10 inches. Anybody got any rail stretchers?
Steve Schantz
11-06-2005 16:36:24
 Re: Questions about the Cletrac General in reply to Centaur Nut, 11-03-2005 19:44:54
I do not have a rail stretcher ,but I do have a parts tractor with good rails and a good tag .E-mail me if you are interested .
Larry from MD
10-19-2005 16:03:57
The serial number is stamped into the frame rail on the right side near the clutch.
