Lesser Known Classics Discussion Forum
Shaw Du-All R9 Electric Starter
Colin Huntley
12-10-2005 18:50:15
I am looking for the electric start system for a Wisconsin Model AHH engine. Any help would be appreciated.
Shaw Du All R9 Electric S
12-17-2005 19:51:37
 Re: Shaw Du-All R9 Electric Starter in reply to Colin Huntley, 12-10-2005 18:50:15
I believe it to be the original motor for my R9. The reasonI am looking for the electic start is it is hard to start with the crank especially as i am getting older. can you help me with the proper paint color.
jdemaris
12-17-2005 17:58:42
I think you can adapt the electric-start parts from an AGN to fit the AHH - which will be easier to find. Is that the original engine on your Shaw? I collect Shaws, but I'm not an expert. My R8 has a Briggs 23F engine and my R12 has a Wisconsin TE.
colin huntley
01-01-2006 11:40:06
 Re: Shaw Du-All R9 Electric Starter in reply to jdemaris, 12-17-2005 17:58:42
I am trying to find the correct color for my Shaw. Also I would like to find some information on the side mount mower that came with the tractor. The mower was not attached at the time that I bought the tractor. I am not sure that I have all the peices for this mower.
Robert A. Johnson
02-01-2006 20:24:17
 Re: Shaw Du-All R9 Electric Starter in reply to colin huntley, 01-01-2006 11:40:06
I found a very good match for Shaw green. It is Zero-rust. Cost is $14. Quart at Link It is self priming, needs a clear coat for UV. Their Gray is an exact match for Wisconsin grey.
Colin Huntley
02-13-2006 17:07:32
 Re: Shaw Du-All R9 Electric Starter in reply to Robert A. Johnson, 02-01-2006 20:24:17
Thanks Robert
This will be a big help when I strat to paint it in the spring I am still looking for a manual showing the mower attached to the shaw.
If i can find a manual or some pictures showing amower attached to a shaw then i would know if I am missing an peices.
Thanks again for the information.
Colin
