Lesser Known Classics Discussion Forum
Help! Carb problems
td6man
02-20-2006 19:15:33
Was given a Gravely GMT 9000 tractor. 26 hp 4cyl Renault engine. After fixing a few minor problems , I am down to the carb, It was full of debris, so I cleaned it and then replaced the diaphragm which was leaking. Now it will only run with me choking it with my hand over it. As soon as I open my fingers slightly, it will want to die. I have tried setting mixture different and adjusting diaphragm a little. The carb is a Solex 32DIS. What next? How do I adjust correctly? Thanks, Dennis
Rick in Michigan
03-04-2006 23:33:00
 Re: Help! Carb problems in reply to td6man, 02-20-2006 19:15:33
Sounds to me like the float is stuck in the closed position and the only way it gets gas is when you starve it for air...besides, if you had the bowl off to clean it and replace the gasket that would be the most logical.
kingmondo
02-21-2006 04:05:43
It sounds like you still have something plugged up in the carburetor. Soak it in a can of carburetor cleaner for a while and try cleaning it out again.
