Lesser Known Classics Discussion Forum
Huber HS or HK manifold
Glenn H.
03-06-2006 07:35:04
Was wondering if anyone makes a reproduction manifold for the Huber HS or HK with a Waukesha engine. I have one of each but are cracked in the same places. Any help would be appreciated. Thanks, Glenn
george md
03-06-2006 18:58:34
 Re: Huber HS or HK manifold in reply to Glenn H., 03-06-2006 07:35:04
Glenn, How bad is your manifold cracked and which waukesha engine is it . I don't have many oliver ( waukesha ) parts but I have some wauk industrial engine parts . I do oxy/acetylene cast iron welding , manifold has to be really bad before I cannot repair it. Below is a link to some cast iron repair and some other things. I'll send you an email with another link to some more repair.
george
Jeff Wenner
03-06-2006 09:16:44
I'm not sure but I think they used the same Waukesha engine as the Oliver 90. If this is true, go to www.rosewoodmachine.com, they make new manifolds for the Oliver 90. I bought one from them for my Huber L which has the same engine as an Oliver 80.
Glenn H.
03-06-2006 11:08:23
 Re: Huber HS or HK manifold in reply to Jeff Wenner, 03-06-2006 09:16:44
I have been on the website and seen the manifolds, but they are a two piece and i'm trying to make it as original as possible. If not that may be my only option.
Jeff Wenner
03-07-2006 09:10:33
 Re: Huber HS or HK manifold in reply to Glenn H., 03-06-2006 11:08:23
The original manifold on my L was 2 peices.
J. Schwiebert
03-06-2006 14:15:29
Double check that Oliver 90 measurements. That 90 head is a little bit of a cross bred as far as the head and port alignment is concerned. The head is not 100% Waukesha also if I remember correctly the bore on the huber is different.
