Lesser Known Classics Discussion Forum
Deutz Electrical questions
Russ Schultz
03-12-2006 01:29:49
Hello,
I got a deutz D65 (F4L514). I want to know how to hook up the batteries. i think its a 24 volt starter. theres 1 ground cable, 1 for the starter and 2 on a relay box. whicg goes where? is this thing a pos or negative ground? Do the glow plugs use 24 volts? just got this thing running, would like to use the electrical on it instead of pull-starting all the time. Thanks ,
Russ
Krouthead
03-24-2006 14:28:18
 Re: Deutz Electrical questions in reply to Russ Schultz, 03-12-2006 01:29:49
The relay box is actually a converter steps down power for lights and accs.you dont need it to just get your tractor started.deutz does not need glow plugs they will start when nothing else will! to get starter functioning without box: wire to ground on (-)neg of 1 battery, short cable from (+)pos of 1st battery to neg (-)
of 2nd battery,cable from (+) pos of 2nd battery to 3/8 stud on starter run smaller wire(#10) fom this same 3/8 stud to pushbutton switch (momentary contact)run 2nd #10 wire from smaller stud on starter(beside larger stud)to other side of pushbutton switch. This will wire around box.If you wish to keep box I have an original wiring diagram as well,email me for info. What type yaer of deutz do you have?
Hope I helped.
Reverend Krout
Bernhard
03-13-2006 11:32:01
1 Plus cable to the starter, connection minus from the first to plus of the second battery. Minus of the second battery to ground, ground is negative.
Take a look at the glow plugs, must be written on them, but they should have 24 Volts, too.
Russ Schultz
03-13-2006 16:04:26
 Re: Deutz Electrical questions in reply to Bernhard, 03-13-2006 11:32:01
this has some kind of electrical box instead of a cable going from positive on bat No.1 to neg on Bat No.2
the box has 2 battery cables on it. which one goes to the negative and which one goes to the positive? i would hate to hook it up wrong and fry something.
thanks, russ
Bernhard
03-14-2006 03:58:10
 Re: Deutz Electrical questions in reply to Russ Schultz, 03-13-2006 16:04:26
the clamps must be signed with + and -. If not the + pole on battery has a bit more in diameter, even the clamb should have.
Bernhard
03-14-2006 04:02:29
 Re: Deutz Electrical questions in reply to Bernhard, 03-14-2006 03:58:10
If You didntīfind anything like I told, try this:
Link
Itīs german related, but the guys should be able to help You out.
Link
look out for "Kontakt" and post your Question.
If there are problems to post it, let me know.
E-Mail: knoex@t-online.de
