Lesser Known Classics Discussion Forum
Clark Michigan 12 tractor shovel
Joe Mechanik
06-05-2006 20:58:13
just got it not too long ago...model # is rubbed off. Has the 2 speed powershift transmission. I need to change the fluid, I know where to drain it, but I'm not sure how much it takes. I also haven't found a way to determine if enough is in the case....I'm guessing I fill it through the filter housing until fluid runs out the lowest check hole ( at least it looks like a check hole)
Joe
oldclarkguy
06-10-2006 05:04:06
 Re: Clark Michigan 12 tractor shovel in reply to Joe Mechanik, 06-05-2006 20:58:13
You may or may not know that the Clark Michigan line was acquired by Volvo Construction Machinery in the 1990s. A Volvo Construction Machinery dealer may be able to assist you with questions about your wheel loader.
Joe
